I agree with everything you said for the most part. Those are the reasons that are always given regarding the change to the new TTY fasteners.
You ARE plagiarizing others! I'm gonna fry you on social media!
(It WOULD help if I had a social media account, I don't.)
I've repair everyday cars and I've had more trouble with the new fasteners than the old...
Replacing TTY head bolts with studs is always seen as an improvement (or maybe we just think it is).
These studs, which are the same thread pitch and diameter (close), normally equal or exceed the original clamp force (most have larger diameter flat washers).
I think the driving force between the change was for a fiscal reason alone.
"These new engine assemble robots will replace 150 employees and over a 10-year period will save us XX.XX million dollars"...
I have yet to see an angle torque listed where they don't also say "replace fastener".
You're right! You can have angle torque without TTY fasteners but that is SO rare that I automatically see a TTY procedure as "replace fastener" as well. I could be wrong, I'd rather make an error of addition, that costs a bit more, than have a critical fastener fail inside an engine.
I reuse TTY fasteners far more often than I would like...
The service manual says replace so I call the dealer; not in stock and 5 days to get...
Shit!
Next questions is "have you ever sold any, especially through your shop?"
If the answer is "no" then I'll probably re-use.
If the answer is "hundreds" I'll bitch and say "Why the hell don't you keep that in stock? you useless parts critter!"
Note: I am friends with most of the parts guys/gals local to me.
