QUOTE(Bucci @ Dec 28 2023, 08:45 PM)
QUOTE(Dave_Darling @ Dec 28 2023, 12:37 AM)
Look to see which relay has the following wires plugged into it:
Red/Black (red with black tracer stripe)
Gray/Red
White/Yellow
White/Blue
That's the fog light relay. The white/yellow is the wire that feeds both fog lights.
--DD
Dave, thank you for your expertise. I’m still in the hunt but getting closer..!
Tonight I was able to energize the fog lights manually by pressing down inside the round relay after pulling the round relay cover off.
What I’ve deducted is there’s possibly a grounding wire on the column stalk switch or headlight switch that signals the fog light relay to be energized. I think there’s an issue with the headlight switch or maybe the fog light switch wire has come off the main headlight switch..???
I probably should look at a wiring schematic to see what color wire goes from the fog light switch to the main headlight switch.
Click to view attachmentClick to view attachmentClick to view attachment12-29-23
Tonight I was able to remove the emergency lighting switch from behind the dash face and I removed the headlight switch from the back of the dash face. Both switches appear to be operating normal, and all wires are intact.
Also, I removed and inspected the turn signal and emergency flasher relay that is mounted on a sheet metal lip underneath the dash behind all the switches to the left of the steering column. I found an article online to diagnose and repair the relay, which I believe is working correctly.
This is for reference only.
http://katdash.com/wp-content/uploads/2016...a2479-short.pdf.
Click to view attachmentClick to view attachmentClick to view attachmentMy next course of action is to remove the steering wheel and horn ring then replace the steering column “stock-switch” that is used to activate turn signals and headlight “brights”.
I’ll have todo that sometime next week. Tomorrow morning I’m headed down to (San Diego) to Gillespie Field airport to help a Buddy change oil and check tires on a 1950 Cessna 170’ passenger airplane.
