@Krieger Interesting assortment of parts. The yellow shaft is for 77-86 911,
The unplated shaft is of a 74-76 911. Both shafts need a spacer. The housing and cross tube will fit a 914 as well 65-73 911. The top spring for 914 or 65-74 911. Next spring for a Sport-a-matic set. next for 914 or 65-74 911 and bottom spring for 74-76 911.
The pedal housing has a bent stop for the accelerator crank. I may be able to use the parts. Did you mask off the threaded studs on the housing?
[/quote]
Dang
@bdstone914 , you're a smart cookie!
[/quote]
If I ever get on Jeopardy and they have a Porsche Pedal Sets category I am going to slay them.
