QUOTE(DennisV @ Jan 4 2024, 04:46 PM)
QUOTE(Superhawk996 @ Jan 4 2024, 11:54 AM)
Are you sure you have 914/6 or early 911 stubs / hubs?
Our car was a factory 914-6. Pretty darn sure they are 914-6 hubs.
Without actually having something to prevent rotation of the hub an impact isn’t going to give you enough torque to tighten properly.
Not sure what you're referring to regarding the rotation and torque. All I did was install the hub into the bearing in the trailing arm as pictured. Using the all thread rod, nuts and impact wrench method referenced in my initial post to pull the hub into the bearing.
If you're talking about the nut that secures the cv joint / drive shaft, I haven't gotten that far yet.Is it wishful thinking that this problem goes away once the drive shafts are installed?
So catching up on posts since yesterday
What still isn’t clear to me:
Which is moving laterally - the inner race or the outer race?
As initially stated - after install the outer race should not move at all. Zero lateral movement between outer race and trailing arm bore. None. Zero, never. With or without retainer - it doesn’t matter. This doesn’t depend on anything else.
The inner race (and by extension the hub mounted within it): These are split inner races. I’ve seen some in the past that use a spring clip to secure one inner race to the other inner race just to keep them from separating and having the balls/cages fall out during shipping and handling prior to install. To a casual observer they might appear to be one piece but they are split races.
Without a CV stub installed and properly torqued (220 ish lb-ft) to the hub - there should be no judgement made about lateral movement of the inner races or the hub. Once the stub and hub/hub nut have been properly torqued (using a torque wrench) then, and only then, there should be zero lateral movement of the hub.
Note; I apologize - in looking at the pictures earlier I should have noted that there are no CV stubs installed. I should have noticed that all we have is the bearing installed into the control arm after the initial bearing install. For some reason I got the impression the whole bearing (including outer race was moving laterally). Shame on me. Hopefully I didn’t make this thread longer than it needed to be to get you a clear answer.
