nditiz1
Jan 11 2024, 08:58 AM
Anyone have a trashed throw out bearing for educational purposes?
Thanks!
euro911
Jan 11 2024, 10:31 AM
I have a used one, but it's not necessarily 'trashed'
Click to view attachmentClick to view attachmentClick to view attachmentIf you press it apart, re-grease it and press it back together it'll be like new - like the tutorial on the 912BBS showed
nditiz1
Jan 11 2024, 10:37 AM
Mark,
How much you want for it? Looking to see how close these are to the 912E ones and if machining can be done as a work around.
Al Meredith
Jan 11 2024, 11:27 AM
I've got a 912E in which I built the 2056 . I'm sure the through out bearing is the same as in the 914. The clutch disc and the pressure plate are interchangeable as well.
nditiz1
Jan 11 2024, 12:03 PM
The 912E bearing does not have ears like the 914. The fork on the 912E looks similar to the 911 ones (72+)
sixaddict
Jan 11 2024, 01:13 PM
I have one ……welcome to it for shipping. Believe it can fit in small USPS box which should be $7 and change. Will confirm in a few…..pp= zztot6@gmail.com
LMK
Terry
sixaddict
Jan 11 2024, 01:38 PM
Sent pm
euro911
Jan 11 2024, 04:02 PM
From reading the thread on the 912BBS, the 912E with the 915 trans takes a totally different (NLA) T/O bearing.
Looks like the bearings for the 914, early 911 & 912 that are mated to a 901 trans are like the one I posted pix of.
The 912E folks on the 912BBS are looking for a supplier to have new ones manufactured.
