QUOTE(Krieger @ Jan 16 2024, 11:30 AM)
Thanks
@Superhawk996 for clarifying my post a little more. I should add wedge bolt style. I wonder if they are the same size anyway?
I would think the ball joint stem that slides up into the strut will be the same OD but I’m not 100% sure.
It sounds like Ninja got you the OD for the late (wedge) ball joint so should be OK. Just wanted to clarify post regarding which style was early vs late.
I assume you were trying to find non-OEM joint or maybe doing something unique for the track car suspension.
