Great video Ian. If the windshield is out, using the zip ties makes the job so much easier. You'll need the tool to tighten the zip ties correctly. I noticed you had a gap in the curved area of the A pillar right around the 8:44 mark. Did you correct that yet? If not try using the zip ties. After 3 failed attempts to snug that seal in the curved area I stumbled upon using zip ties.
Very cool idea Kent! The curve on my install relaxed after a few weeks and looks good now. I probably should've mentioned that in the video. Also, the characteristics of repo seals aren't quite the same as OEM. The fact that the tab needs to be trimmed is a case in point. I assume that the new seals are slightly stiffer, which also keeps the curve flatter...requiring zip ties or time.
