QUOTE(Rikky74 @ Jan 21 2024, 03:59 AM)
QUOTE(wonkipop @ Jan 21 2024, 10:42 AM)
first of all its a VW color not a porsche color.
its tangerine.
which may as well be phoenix red (74 color)
but.
anything red from the 1970s was created with cadmium
now a banned material (like lead = poison).
also the actual paints, glasurit are difficult to source as they are also consiidired as greta thurnburg grade morally condemned. so its tricky.
but to assist its a VW color not a porsche color.
good luck. i am interested to know how you go with it.
i have a phoenix red 74 914 and i have serious doubts the original color can be exactly reproduced.
Thanks, but all the colours you are mentioning are different colour codes; Tangerine (L21E) Phoenix Red (L32K) so looks like I am still searching for the L20E of VW, but based on the discussion I had with the paint shop, L20E Porsche and VW were the same recipes. Anyone else a different view?
apologies re the color code on the door plate.
i foolishly went straight off the external color of the car in the photo.
however i believe
@Superhawk996 is correct.
it sure does not look like its painted L20E or signal orange.
here is signal orange.
https://www.colors.rs/colorsearch?tag=w~ezm...p;searchtype=rsby the looks of the image you included of the door jamb that sure does look original paint in there without a doubt. door hinge pins unpainted from factory. and it looks tangerine. or blood orange as it was also sometimes called. i think it was called tangerine in the USA. i know the exact same color was referred to by its european naming protocol in australia. it was called blood orange.
photos can be deceiving. but i don't think that much. the car would look a lot yellower i believe if it was signal orange L20E.
it would not be the first time a 914 had a wrong label or mistake from factory.
rare but did appear to happen.
i am not sure what you need the paint for.
is it a touch up area.
you say you ordered a spray can from porsche.
i imagine it was not too much money or cost.
try ordering a can of tangerine L21E if its a reasonable small cost.
see of you can get hold of it and do a test with that.
a year or so back another member of this website was trying to get hold of solvent based glasurit paint (original glasurit formula paint). it was for a 74 color. he was having no luck in the USA.
as far as i know its a possibly a similar problem in Europe by now. they have stopped making it as far as i know. all water based with clear coat over.
as i mentioned the reds are particularly tricky. very tricky.
