QUOTE(aturboman @ Jan 25 2024, 03:42 PM)
For clarity the early style image I posted is on a 914-6. I know early 4 cyl are also rounded but I am not certain if the mounting feet are in the same place but I suspect so.
The early 4 cyl muffler is smaller than a 6 so I don't see why it would need different placement under the trunk, plus the real estate is very limited where is sits.
I’ve highlighted the location of the mounts on the six, you can make out the Phillips heads if you squint. Clearly different from the four shown earlier.
