QUOTE(930cabman @ Jan 26 2024, 02:22 PM)
there must be an inspection procedure for checking the throttle shaft/housings fit? Other than many complaints of this, I have not found a method for checking other than wiggling the shaft when the motor is running.
Sealed bearings vs bushings minimize leakage
If bushed the answer is zero play beyond that to allow free rotation (approx 0.001-.002”). Measure with dial indicator - no guessing allowed
Or feel free to set up a flow bench and measure leakage.
Oh - on running engine, starting fluid much more definitive than just wiggling and waiting for air to bleed and make it lean. Be careful!
