@16:15 ish Note we now make the seal with a fuzzy strip on it so the glass will not grab it. The OEM didn't have it so when we 1st made it we made just like OEM. Since the later seal is really a 911 seal that was used in place of the early seal, the late one grabbed.
Also, if you roll the window up a little you can use a wood block to press the seal into the channel. If you channel is dorked up where folks have used screw drivers to open it up we have new ones. Both early and late (as well as the early rubber seal).
https://914rubber.com/late-outer-window-scr...eal-w-fuzzy-set
