QUOTE(mepstein @ Feb 5 2024, 08:11 AM)
I re-upholstered a pair of seats using the 914rubber kit. It’s pretty easy if you take it step by step. I took one seat apart, documenting as I went. That and some threads on world gave me the info I needed to do the project. The only things I purchased was a pint of weldwood contact cement and a cheap heat gun.
The most important thing to understand is the process takes some time. You’re not going to get it done in an afternoon. Even just letting the glue dry between multiple coats takes 30+ minutes each time.
But if I can do it, anyone can.
The key part of this post, or a key part, is to take only one seat apart at a time. That way, you still have a successful original seat assembled to refer to.
