Hi all.
I put in 250 pounds of batteries in the front, but I took out the spare tire (35 lb) and the fuel tank, and the headlamp motors (11 lb): so, I have a net plus weight of around 90 lbs, and I kept it fairly low in the front. Rear is about the same as it was. I seek opinions on torsion bars for the front. I’m thinking of going up to 20mm Sway-Aways in front, I have 100lb Weltmeisters in the rear.
Speaking of the rear, I’m putting in new Bilsteins. There are like 7 grooves for the bottom spring perch to sit in. My old springs were 12-1/2 inches oal. Weltmeisters are 15” oal. There are about 15mm between ring grooves…so, it’s not infinitely adjustable, but will adjust in 15 mm increments. I imagine I can get balance pretty close with the 15 mm increments? I think I put the bottom perch 3 grooves up, which makes the assembly the same length, old vs. new. I guess I’ll find out when I set the car down and align it.
TIA
Pat
