QUOTE(windforfun @ Feb 7 2024, 10:19 AM)
I've used that for decades.
I was calling it the wrong name. I called it A&P or NASA style.
They just appropriated it from someone else!
I've tested three splice spans (20,16,14) for both resistance and failure.
No difference in resistance on a Fluke 87 and they never failed at the splice when the wire was shock tested to breakage.
In 30+ years I've never had to re-do a splice done this way.
For the last 8 years I have been using type 2 heat shrink with the glue lining.
Once you get "good" your spice will look like you just added heat shrink to a wire.
Almost no diameter change.
