Thunderchief
Feb 12 2024, 01:37 PM
Does anyone know what this sound insulating material is and if it is recommended/helps cut down noise?
dr914@autoatlanta.com
Feb 12 2024, 02:06 PM
die cut engine insulator pad made from dynamat and yes it does fit perfectly
http://www.autoatlanta.com/Porsche-914-Eng...1455613510.html
windforfun
Feb 12 2024, 05:24 PM
QUOTE(dr914@autoatlanta.com @ Feb 12 2024, 12:06 PM)
http://www.autoatlanta.com/Porsche-914-Eng...1455613510.htmlAm I going blind? The two pictures don't show the same material. Yes?
FlacaProductions
Feb 12 2024, 05:34 PM
burton73
Feb 12 2024, 05:37 PM
They are not the same brand. George is telling you that his are made of Dinamat. Dinamat has Bk Wolds all over it in less it changed. Now his may be made of the very same specification. But I'm not going to pissing match over it. Let’s just assume that
“you can get anything you want at Alice's restaurant. Accepting Alice.”
No, really George at AA has a lot of 914 stuff. He has a way, Subtle way of telling us.
Good guy and he will answer all your 914 questions at any time. It is one of the great pleasures of his life. So everyone take him up on his open offer to help you with your questions
Bob B
windforfun
Feb 12 2024, 05:41 PM
QUOTE(burton73 @ Feb 12 2024, 03:37 PM)
Bob B
I've been buying from George for almost 20 years now. Regarding noise suppression, the thicker the material the better. It's like sheet rock without any insulation underneath.
NARP74
Feb 12 2024, 05:49 PM
For George, it's called advertising and marketing...
And it's Excepting Alice... can't get her.
Craigers17
Feb 12 2024, 06:41 PM
I can't promise you that this is EXACTLY what this particular person used in his engine bay, but it's something very similar to this:
https://www.google.com/url?url=https://www....eWY0vmxQHCU3YWWI feel like you could do the same thing with some cheap heat mat from Amazon like this, but I've not tried it.
https://www.google.com/url?url=https://www....AKfANRLUiTp2EGd
KELTY360
Feb 12 2024, 07:10 PM
QUOTE(Craigers17 @ Feb 12 2024, 04:41 PM)
https://www.google.com/url?url=https://www....AKfANRLUiTp2EGdFinally someone answered the simple question the OP asked.
Steve
Feb 12 2024, 07:12 PM
I would love to put a pad back their, but there was surface rust underneath the last one. If someone can guarantee no rust with a pad, then I will install one.
partwerks
Feb 12 2024, 07:33 PM
Could put that Lizard Skin, I think it's called there.
fixer34
Feb 12 2024, 07:43 PM
Just remember, you have the equivalent of a large vacuum cleaner nozzle pretty close to that pad, so make sure it is well secured.
Superhawk996
Feb 12 2024, 07:47 PM
Dynamat publishes data on noise attenuation of their materials.
Without data - it’s just unverified marketing claims.
BillC
914Rubber sells, or used to sell, an almost-exact-match-to-original replacement engine firewall padding that doesn't absorb/hold moisture -- I installed a piece on the "dapo special" 3 years ago. I just looked on their web site, but couldn't find it (
@Mikey914 ? ) .
windforfun
Feb 12 2024, 08:05 PM
QUOTE(Superhawk996 @ Feb 12 2024, 05:47 PM)
I studied acoustics in grad school from the guy who overhauled Avery Fisher Hall at Lincoln Center. Much depends upon the frequency bandwidth of the noise. It's not all about acoustics, but also mechanical vibration. The later is almost impossible to kill depending upon how it propagates through the structure.
Geezer914
Feb 12 2024, 08:10 PM
I used Dynamat on the firewall and installed the silver backpad overtop. Much lighter than the original.
bkrantz
Feb 12 2024, 08:40 PM
On the engine side of my firewall, I used a foil-covered closed-cell foam, so that it does not retain any water.
Root_Werks
Feb 12 2024, 09:13 PM
QUOTE(BillC @ Feb 12 2024, 05:47 PM)
@Mikey914 ? ) .
I installed a 914Rubber engine pad on my six. It made a difference inside the cab.
Mikey914
Feb 12 2024, 11:24 PM
@Mikey914 ? ) .
Actually doing another run now. Will have listed up shortly.
FlacaProductions
Feb 13 2024, 10:45 AM
VaccaRabite
Feb 13 2024, 10:52 AM
QUOTE(Steve @ Feb 12 2024, 08:12 PM)
Dude, you can't even make that guarantee with PAINT.
I will say that the modern pads that don't hold water are less likely to add rust, and make a significant difference to in-cabin noise.
Zach
JamesM
Feb 13 2024, 11:39 AM
QUOTE(partwerks @ Feb 12 2024, 06:33 PM)
I shot LizardSkin (2 layers of their sound deadener and 1 of their ceramic insulation) on the inside of the firewall. Engine bay side is going to remain bare, which was stock for a 72.
Click to view attachmentClick to view attachment
Mikey914
Feb 13 2024, 11:43 AM
We used Raptor tinted to the body color for Taylor's car. Then if you put a pad on it, it will not rust. Wanted to see how much sound deadening it offered 1st. BTW did both inside and outside as well as floors. No tar going back on those.
rhodyguy
Feb 15 2024, 08:11 AM
914s are treated differently now than 2nd or 3rd owners in the late 70s early 80s. Who runs open cell batteries and parks their 914s to the elements in 2024? Lives with leaking seals? No one. Owners are fixing rot, not promoting it.
How many pieces are there to the AA offering? What’s with what appears to be slits in installed product?
Steve
Feb 15 2024, 08:57 AM
QUOTE(VaccaRabite @ Feb 13 2024, 08:52 AM)
Zach
but without a pad, I can clean the area and look for rust versus rust hiding under a pad i glued on.
NARP74
Feb 15 2024, 09:10 AM
I think the new pads are stiffer and lighter and might not even need to be glued on. If you have the perimeter hold downs and the couple of hardware pcs, like 914 rubber sells, you might be OK. Be easier for inspection. I am not sure if it sags over time or heat cycles. This is on my list, maybe someone with experience can chime in.
