FlacaProductions
Feb 12 2024, 05:00 PM
Greetings,
Ordered wires for a 74 2.0 from a very respected Type 4 supplier. Magnecor 40442's were listed as correct.
When they arrived, I noticed they have right angle connectors at the distributor and rubber connectors for the plug end. This was not noted online.
Are these good to go for a stock 2.0?
(If all goes well, it'll be running a 123 distributor)
windforfun
Feb 12 2024, 05:03 PM
QUOTE(FlacaProductions @ Feb 12 2024, 03:00 PM)
Greetings,
Click to view attachmentThose are fine. At least they don't have left angle connectors. I like the way the writing on the wires runs in the same direction.
Chaznaster
Feb 12 2024, 07:25 PM
I thought 2 and 4 need the longer reach connectors at the plug end as the sheet metal rises towards the front of the car. I am pretty sure that's how mine are set up.
Chaznaster
Feb 12 2024, 07:26 PM
Duplicate
Chaznaster
Duplicate
Chaznaster
Duplicate.
windforfun
Feb 12 2024, 07:42 PM
QUOTE(Chaznaster @ Feb 12 2024, 05:25 PM)
Just pull the grommets up. Yes? The lower one on the right has its grommet pulled away from the connector. Doesn't the one on the lower left appear to be longer?
FlacaProductions
Feb 13 2024, 10:44 AM
connectors are all the same length but the grommets do slide.
VaccaRabite
Feb 13 2024, 10:55 AM
I've used these before. They are good.
Zach
FlacaProductions
Feb 13 2024, 11:13 AM
Geezer914
Feb 13 2024, 04:31 PM
Check out MSD 31939 spark plug wire set.
FlacaProductions
Feb 13 2024, 04:48 PM
ah - thank you. very similar.
jim_hoyland
Feb 14 2024, 07:20 PM
QUOTE(Geezer914 @ Feb 13 2024, 02:31 PM)
What boot does the 1-2-3 distributer require. I noticed the MSD 31939 set doesn’t have one.
windforfun
Feb 14 2024, 07:29 PM
FlacaProductions
Feb 14 2024, 08:00 PM
123 cap is same as a bosch OEM - strange that the 31939 doesn't have both connectors.
Geezer914
Feb 15 2024, 08:12 AM
They provide a boot and connector in a separate package as you have to cut your coil wire to your length.
DRPHIL914
Feb 15 2024, 08:57 AM
QUOTE(FlacaProductions @ Feb 12 2024, 06:00 PM)
Greetings,
Click to view attachmentthose look nice, who is the supplier?
jim_hoyland
Feb 15 2024, 09:21 AM
QUOTE(DRPHIL914 @ Feb 15 2024, 06:57 AM)
Greetings,
Summit sells them
FlacaProductions
Feb 15 2024, 11:42 AM
https://lnengineering.com/porsche-914-2-0-m...n-wire-set.html @DRPHIL914 - Still on sale - $96 from $129
I didn't call them out originally just in case they were wrong - but I love doing business with LN.
DRPHIL914
Feb 15 2024, 11:49 AM
QUOTE(DRPHIL914 @ Feb 15 2024, 09:57 AM)
Greetings,
QUOTE(jim_hoyland @ Feb 15 2024, 10:21 AM)
Greetings,
Summit sells them
QUOTE(FlacaProductions @ Feb 15 2024, 12:42 PM)
agreed i do like dealing with LN as well. I would think these should be compatible with the 123ignition distributor, yes?
FlacaProductions
Feb 15 2024, 11:58 AM
I wouldn't see why not. That's what I'm planning on.
GBX0073
Feb 15 2024, 10:30 PM
They work I have them
will fit the stock coil.
but If you're trying The Black 1.5 Ohm Epoxy Coil from 123
(I was looking for more spark used on the six )
The Elbow is a dis-advantage to the larger/deeper connection with that coil
FlacaProductions
Feb 16 2024, 11:39 AM
QUOTE(GBX0073 @ Feb 15 2024, 08:30 PM)
but not the Black 1.5 Ohm Epoxy Coil from 123
Interesting - what's the issue?
jim_hoyland
Feb 24 2024, 06:12 PM
I just installed the new LN Magnacore wires; idle seems smoother.
I noticed that there was no sales tax charge ; said it’s an out of state sale.
FlacaProductions
Feb 25 2024, 10:18 AM
Thanks
@GBX0073 - our replies crossed. I have both a stock and a 123 1.5 coil so i'll be aware of fit issues - thank you.
@jim_hoyland - good to hear!
GBX0073
Feb 25 2024, 02:21 PM
Brian
Hope the next visit back to Indy has you up and running again !
QUOTE(FlacaProductions @ Feb 25 2024, 10:18 AM)
Thanks
