Ok, it's been a while and I wasn't sure if this was the best place or maybe the FB group. This feels a bit more appropriate so here goes. I have basically broken my '74 down to wiring, steering and suspension. Pretty much gutted everything else. When I originally asked my question back in July (project start) some of you directed to me to build a cart based on Jeff Hails build vs doing it on a Rotisserie. (see pic) I purchased and cut all the steel to build the cart but the more I researched the more I kept seeing restorations being done on a Rotisserie. I have all the materials to build either, I just don't know if that is the best way to go about this. A few things. 1) The measurements from front pillar to rear is good (25 1/8 52 5/8). So no sagging or twisting yet. 2) The pictures show the condition of the passenger Long, it's in pretty rough shape and assume I'll be replacing most of it. 3) The floor has some small holes so I figure I'll just replace the entire floor. 4) Obviously, the jack point is completely gone. 5) Inside the engine compartment isn't horrific, but isn't great. 6) Inner firewall where it meets the floor pan has some issues that I think I can patch versus replacing the entire inner firewall. 7) Trunk/Frunk will both be replaced. Out side of that the rest of the car is decently solid surprisingly. Including under the fender on the passenger side where the long extends up.
With all this said (and shown) what is the recommended approach? I just turned 55 (this week! Woo-hoo) so the idea of working on the long/floor on a Rotisserie is WAY more appealing that crawling my fat tired arse underneath and trying to weld up when it's on a cart.
With this said if anyone thinks trying to do these repairs on a rotisserie is going to likely cause sagging/twisting it's obviously a better choice. So before I start building either just wanted to get the group's expert opinions. Given no sag/twist has occured yet will the door braces be enough to keep everything in place if I go Rotisserie route? (I can always add more bracing for floors, etc.) Or is not worth taking the chance?
Appreciate any and all input. Thanks!! Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=902
189]Click to view attachmentClick to view attachmentClick to view attachment[attachmentid
=902188]
