QUOTE(ChrisFoley @ Feb 22 2024, 05:12 PM)
As Greg said, no need to overthink it.
Either rivets or screws, your preference. The entire assembly is held by three fasteners. The boot is held by the raised lip of the bearing retaining plate. A small recess on the frame helps the boot rim fit better. Orientation of the bearing is critical. I zip tie the 3 piece assembly in it's correct orientation before shipping.
Indeed in hand is more intuitive. That said I think the perspective of the catalog shot aided my confusion. You really don't get the sense how deep the rivets are. They easily go through the bearing cage.
Also in the catalog shot it shows the screws in, (on top of in my mind) the mounting rivets. The instructions clearly then note "alternative mounting option". Confusion lifted!
I did not realize until digging in that the firewall pass through is not parallel to the firewall plane. It tilts in towards the drivers side.
Noted, place the cage but against the opening and drill.
given the slight offset of the of the mounting surface a little widening of the drilled holes was needed to fit the rivets
Even then all the rivets did not fully seat
a small deep socket works nicely to tap it down to fully seat.
Pulling the rivets was fun on the garage floor with the car 12 inches off the deck.
Interestingly the 7oclock rivet did not self trim the mandrel though the other side mushroomed fine.
ant the 5 oclock rivet "failed" i.e. did not mushroom but seems ok as there was enough tension to cut the mandrel. If it ever fails I'll drill the rivet and use the screw.
Finished
Thx all
