I note that 914-6 GTs have battery cutoff switches mounted on the cowl and some were mounted inside on the tunnel behind the shift lever. Were they in both spots?
I'd like to move mine from the frunk to inside the cabin. Currently, there's a positive lead running from the funk mounted battery to the starter--trough the inside and along the door side of the passenger seat. I'd like to reroute it to the tunnel and install a cutoff switch.
Or maybe I just move the battery back to where it was? But that's an entirely different discussion. Not sure why it was moved forward.
Thanks, John
