sixaddict
Feb 24 2024, 10:47 AM
Trying to sort through information for gearbox build.
In Georges book it says -4 and -6 ring and pinion gearing is different but does not explain or detail R&P ratios. He lists 1-5 ratios for each.
Could someone tell me the actual numbers.
Caveat not to mix but
Second and third ratios are a few decimals different. that does not seem like much whereas fifth has greater spread.
Any words of wisdom.
sixnotfour
Feb 24 2024, 10:58 AM
Stock gear ratios:
1970-1976 914/4: 11:34 A, 18:34 F, 23:29 N, 27:25 V, 31:22 ZD
1970-1972 914/6: 11:34 A, 18:32 GA, 23:28 O, 27:25 V, 29:22 ZA
Final drive 7:31
mate914
Feb 24 2024, 11:03 AM
QUOTE(sixaddict @ Feb 24 2024, 11:47 AM)
Other than side and tail shift. The only diff i know of is gearing.
Matt
Dr Evil
Feb 24 2024, 07:16 PM
R/P are same across all 914.
sixaddict
Feb 24 2024, 07:47 PM
That was my basic question.
Thank you!
M
QUOTE(Dr Evil @ Feb 24 2024, 05:16 PM)
T.Rick6
Feb 24 2024, 09:26 PM
I thought the difference between the two was the 914-6 has a 904 main shaft??? Could be mistaken ..
Also stamped with 914/01
Feb 24 2024, 09:29 PM
904 main shaft never came stock on any 914 box. LSD was an option on 4 & 6.
rgalla9146
Feb 26 2024, 09:27 AM
The tail shift linkage for 4cyl. and 6cyl. are different from rear of tunnel into
gearbox.
