Thanks, friends.
QUOTE(windforfun @ Feb 25 2024, 05:33 PM)
Does the blue light in the instrument cluster come on? I hate intermittent electrical issues.
Not when its supposed to... lol. It comes on when the headlamp switch is in the half (parking lights only) position. Then when the switch is pulled fully out for headlamps, it goes out... and no high beam switching changes that indicator light or headlamp illumination.
QUOTE(peteinjp @ Feb 26 2024, 09:34 AM)
Sorry- I had it backwards- the high beam filament acts as the ground for the fog relay. When the high beams are on the fog relay is no longer are able to ground though the filament.
Yeah, I did know that. I thought it inhibited the switch from illuminating also but apparently the switch illuminates anytime its in the on position, regardless of if the foglamps are lit or not. This I forgot. I havent driven the car since 2019, lol.
QUOTE(ClayPerrine @ Feb 26 2024, 07:41 AM)
Start with the high/low relay on the back of the relay board. It is a square silver can that has a metal clip holding it to a hole in the relay board. If it is not clicking when you pull the turn signal stalk, then the light are probably stuck on high beam. I would replace it, as they are fairly cheap.
So... with the key in on position, and the headlamp switch in half (parking light only) position, the high beam indicator light is lit (headlamps are still down), but as soon as I pull the headlamp switch to the full on position, headlamps do go up and both are lit (I cant tell if high or low) but the high beam indicator light goes out... and switching them with the stalk from high/low/high/low, the relay is clicking but no change is occuring in the headlamps... and in no position do the fog lamps actually illuminate (the switch lights up but no actual lights from the fogs).
Then when I pull the left high beam fuse, the fog lamps operate as intended (except when I try to click the high beams on, which, because I've pulled one of the fuses, they are inop).
I may replace the headlamp relay as you suggested (possibly the headlamp switch too as sometimes it doesnt work correctly) but the relay seems to be working correctly... at least clicking as if it is. The operation seems to vary on a number of things, none of which result in correct operation, lol.
I havent even had time to get back on it. I'll take a video next time I'm in the garage.
Thanks again,
- Rich
