Nice execution
@Geezer I assume that is FG? I see that that you "filler door assy" is recessed into the hood
To clarify, Im doing a replica GT filler installation into a stock steel hood.
SM sells a pretty nice kit with the essential pieces.
Once installed it provides for rain catch & drain but to continue to use the charcoal evap system & tank you need to ditch the early filler neck "catch" but it looks like you could still fit the tank?
The late plastic evap tank you cannot use.
And somewhat importantly, you need to start with the early tank which has different mounting tabs.
