QUOTE(emerygt350 @ Mar 6 2024, 09:48 AM)
Assuming d-jet, stock, first stop would be the AAR. Sounds like a vacuum leak. About 6mm or so in size. Check all your vacuum hoses as a first move.if your AAR is stuck open, 1600 sounds about right though.
when i first got my car i had the same issue, high idle, and the areas that are the main cause of vac leaks will be an open AAR, disconnected or bad vac lines, or leaks between the throttle body and plenum, or the intake runners, also cold start valve location.
Also if it is running lean you will have a higher idle.
Order new Vac line kit from AAtlanta and get the new gaskets for all above. .
Good luck, should be able to sort that our fairlly quickly.
Phil
