QUOTE(porschetub @ Mar 10 2024, 05:35 PM)
QUOTE(rgalla9146 @ Mar 10 2024, 01:30 AM)
It's common.
It's not from water leaking in. It's from condensation.
Get the neck and the 54mm clamp replated.
Your cap is probably crusty too.
the moisture/condensation is part of the process as the oil heats up and if your breather is hooked to a vacuum source to draw that corrosive vapor it will be fine.
I learnt a lesson with the wrong filler vent set up, did a few tests and hooked up a piece of PVC clear fuel oil rated hose to the stock aircleaner , interesting how I could see small droplets of condensation heading down the hose ,had no milky sludge anymore under the filler cap now but rusty as old system caused that
Good solution for me, could well be others, cheers.
all true.
would add. car needs to do steady state driving to pull that water vapor through the engine combustion process and needs engine/oil to be hot enough to release vapors.
(same goes for hydrocarbon impurities absorbed into crankcase oil). got to get it hot and got to drive it somewhere where you can cruise steady for extended period.
(same goes for purging the charcoal can if you still got one).
why i like to drive my 914 minimum 1/2 an hour if i take it out, preferably an hour.
getting hard to do where i live at moment but so far so good.
nice thing about a 18 L jet is the cap and filler is plastic.
but the bit below that is still metal like the D jets?
i have noticed if i don't get to drive it enough in winter occasionally i do get a slight milky residue in the top of the filler pipe below the cap. thats with all the crankase evap system intact too.
the crankcase vent system isn't open to draw fumes all the time, at least in an L jet.
i'd have to look it up again, but its only at certain times with engine vacuum conditions.
from memory its during steady state cruise when the throttle plate is open.
could be wrong but i think that is right.
the L jets have a filler cap that is actually the PCV valve and there is a diagphram in it rhat responds to inlet vacuum.
D jet could be completely different of course.
and of course with a porsche 6 - thats a huge volume of oil its got, that you got to get hot to drive the water vapor out of it.
