Help me wrap my head around this. I "think" that when I pull the heater lever it grounds the relay and sends 12v to the blower motor. Is that correct? Also, what powers the small bulb on the Blower indicator next to the lever? I only have one black wire connecting it and from what I can tell from the flow chart it appears to be positive coming from fuse 9. Is that correct because it's not getting 12v with the key on. I do see a small screw - see pic's - should it receive some connection. If so, where does the bulb get its ground? Also, the wires connecting the blower are faded so I'm not sure which is which. I'm not getting power to either one presently so the volt meter isn't helping any. If it's reversed won't the motor simply run backwards since it DC? TIA, Kent
