Gatornapper
Mar 13 2024, 07:24 AM
Ok, searched here & elsewhere with no success, but both my headlight buckets need adjusting in both the up and down positions, and I cannot find anything on it.
I think there is a screw behind the bucket in frame that is accessed from the frunk that adjusts the bucket angle in the upper position. Turning screw clockwise allows the bucket to open more with top rear moving further to the rear.
Is this correct?
How do you adjust the bucket's lower "down" position? Both mine are a tiny bit too high in front when down.
TIA to all for the help.
GN
bdstone914
Mar 13 2024, 07:47 AM
@Gatornapper It only limits upper travel. Lower travel is a function of the
lift arms
Mar 13 2024, 09:09 AM
Do
NOT use the bolt to try to limit the headlight movement, it's not a stop!
http://www.914world.com/specs/headlight_adjustment.php
DC_neun_vierzehn
Mar 13 2024, 09:15 AM
QUOTE(SirAndy @ Mar 13 2024, 09:09 AM)
Do
http://www.914world.com/specs/headlight_adjustment.php Wow. Super helpful. Thanks for sharing. Can't wait to go through this process. My headlights don't pop up in a synchronized fashion and it has always bothered me.
Root_Werks
Mar 13 2024, 11:26 AM
QUOTE(SirAndy @ Mar 13 2024, 08:09 AM)
Do
http://www.914world.com/specs/headlight_adjustment.php Reminds me my last night drive I noticed one of the headlights shook a little when going over bumps. Need to figure out which side and adjust that "anti giggle" bolt.
