Your avatar looks like a 75 or 76, so scissor type. You need to strip the door basically. The window is basically the last item to come out. Even then you probably will have a fit removing that piece. The screws a very small Phillips head and will usually strip out when force is applied. sometimes you can reach the screw shank from behind with a pair of side cutters/dykes and get a grip to turn but otherwise you will need to drill them out with a small (3/32") bit. Small because you need to go back with another sheet metal screw and you don't want something with a large head that will negate the fuzzy strip protection.
