Anyway, got the dizzy in and the car started pretty quickly. Everything went smooth until I mixed up cylinders 1 and 2 and had it all whacked for a while (honestly, I think I'm at the point in my life where learning something new means forgetting something I used to know like the back of my hand....like where cylinder 1 is on the type 4. In fairness to me, I didn't wrench on my teener all last year while I was working on my boat, but still...I hereby turn in my official teener card in shame ).
Anyway, got that sorted after a bit and then we tried to make sure we timed the dizzy so it matched the phone app. Shot the timing light for 27 with the curve at 27, so in theory we were calibrated dizzy to app. Then we put in the basic curve so he could drive home. Car pulls strong and feels good with two exceptions:
1. There's a slight hiccup (as he describes it) between 2200 to 2800 RPM. He's not saying a "flat spot," but rather more like something intermittent that I would associate with a loose plug wire or injector ground. Curious, though, that it does it consistently at that RPM range. Can a misadjusted curve do something like that?
2. Car is idling around 1600 now with the idle bypass fully closed and even with total advance (static and crankshaft) at 0 for 500 and 1000 rpm. Tried plugging up the vacuum advance line and hooking up the vacuum retard, but that had no effect. On my old 123 dizzy I used curve "B" with retard, and that's what got my idle to behave. Assuming we don't have a vacuum leak somewhere, and assuming we correctly timed/calibrated the dizzy, how else do we get idle to cooperate? I see the MAP curve has some potential to do this, but it's kind of confusing on 123's website, and I am kind of surprised that I don't see anyone else here, AFAIK, using the MAP curve.
We're probably doing something basic incorrectly on the centrifugal advance curve, but it's not clear to me what that is. Still learning the app...
