BMartin914
Aug 22 2005, 08:33 AM
I've got the impeller housing off and am trying to find the oil pressure control piston plug. The relief piston is obvious on the bottom, but I can't seem to find this "12 point plug" on the left side of the motor.
Can I get to it without removing tin? The Haynes diagram is very vauge and UNhelpful.
Aaron Cox
Aug 22 2005, 09:11 AM
on the side of the motor.... under the pushrod tubes.
use a 3/8 extension (the square part) fits perfecto!
someone has to have a pic.....
left side...recessed... under the pushrods
bd1308
Aug 22 2005, 09:12 AM
oh i've seen that....
i was wondering what that was....
Joe Ricard
Aug 22 2005, 10:53 AM
Why are you messing with it? Is your Oil pressure to low? Weltmiester makes a kit that has a longer piston and stiffer spring.
If the motor leaks a little now it really will leak then.
Aaron Cox
Aug 22 2005, 10:55 AM
QUOTE (Joe Ricard @ Aug 22 2005, 09:53 AM) |
Why are you messing with it? Is your Oil pressure to low? Weltmiester makes a kit that has a longer piston and stiffer spring. If the motor leaks a little now it really will leak then. |
no stiffer spring joe.
they are 'TALLER' which preloads the spring, making it harder to bleed off pressure, thus boosting your oil pressure.....
BMartin914
Aug 22 2005, 12:06 PM
QUOTE (Joe Ricard @ Aug 22 2005, 08:53 AM) |
Who said anything about oil leaks?
I am installing a front cooler and a HF pump and the pistons to go with it. The weltmeister piston kit is in the box with everything else awaiting installation.
Jake Raby
Aug 22 2005, 12:35 PM
QUOTE |
The Haynes diagram is very vauge and UNhelpful. |
Thats why I made this video.
http://www.aircooledtechnology.com/store/p...09&cat=0&page=1
Not all TIV engines had this plug/piston.. if you have it it'll be between the pushrod tubes on the #1 cylinder..
davep
Aug 22 2005, 01:30 PM
Jake, I thought you were in your 'hole' working hard and incommunicado?
hmeeder
Aug 22 2005, 05:24 PM
BMartin914
Aug 22 2005, 08:58 PM
QUOTE (hmeeder @ Aug 22 2005, 03:24 PM) |
Thanks everybody. hmeeder - YOU ROCK!
