QUOTE(emerygt350 @ Apr 2 2024, 07:12 AM)
That switch is a poorly over engineered POS.
50 year old part fails - POS
Wait till all these”modern” cars are 50 years old and the silicon and PCBs are failing
The dimmer is just a rheostat - if dirty or corroded, DeOxit will work wonders. The switch can be opened up and repaired if you are careful and patient. If the actual rheostat slider has mechanically worn out and won’t stay in contact with the wire wound element, time for a new (used) switch.
Here’s link to disassembly / internals.
https://www.pelicanparts.com/techarticles/9...lamp_switch.htm
