QUOTE(dr914@autoatlanta.com @ Apr 5 2024, 09:08 AM)
Kevin just asked me what I thought were the most desirable 914s to own after the sixes, GTs and limited editions. Here is my list and briefly why. What do you think?
Kevin, here are my ratings after, like you said, the LE and the 914-6S and GTs. starting with the most collectible
ANY low mile (under 30 thousand) original paint original original untouched 914
next we are assuming that one buy the best of these that can be found in original condition, modifications like color change carburetion and previous wrecks and rust skew this rating, so please keep that in mind
1. 1976 914. Last year of the car, lowest production numbers of all of the four cylinders, all were 2.0 models, all of the latest factory chassis reinforcements
2 1973 914 2.0. had standard all of the factory options and the lighter body with chrome bumpers and fuchs alloy wheels
3 1974 914 2.0. Just as good as the 73 but one has to watch which options were on the cars as they came stripped and one would have to order each option separately that the 73s had as standard
4 1975 914 2.0. The reinforced body, the 2.0 engine, the impact bumpers which made the car actually more stable at high interstate speeds
5 1974 914 1.8. The fabulous 1.8 AFC fuel injection the light body, the standard styled steel Lemmertz wheels, the optional chrome bumpers, fuchs wheels etc
6 1973 914 1.7. The first year of the updated shift linkage, side impact door guards, updated window mechanisms
7 1975 914 1.8. Reinforced body, impact bumpers, styled steel wheels as standard, plaid interiors, and optional fuchs or mahle wheels
8 1972 914 1.7 (all fours 70-72 were 1.7). First year of the movable pass seat, ability to have or add retractible seat belts
9 1971 914 1.7 Naugahyde leather look interior, improved chassis reinforcement
10 1970 914 1.7. Just owning a 914 is a great experience and finding the first year is harder because they were dirt cheap back then and people abused them so very few are available
I love all 914s but find im more interested in owning the 72-74 cars.
As delivered by the factory my #1 pick would be the early-mid 73 cars with the late style window winders but without the side impact beams (I have owned 3 73 cars and each one of them has had different style doors) This to me was the "peak" of 914 development after they had fixed a lot of the problems with the early cars and before they started cost cutting and implementing changes for government regulations.
You didnt mention some of the more interesting cars like the 74 LE cars and the initial production 73 2.0 vinyl A-Pillar cars.
My preference list looks a bit different, this is from the point of a car you plan to drive regularly.
1. Mid 73 (1.7 or 2.0) with no door beams
2. Late 73 - Early 74 2.0s (pre plastic gauges)
3. 72 1.7s (though preferably with a side shift conversion)
4. Late 74s (1.8 or 2.0) (plastic gauge cars)
5. 75-76 2.0s (I make no distinction between these as the 76s were just burning up remaining 75 inventory)
6. 75 1.8s
7. 70-71 1.7s
Ultimately though if your focus is to drive and enjoy your 914 though than any 914 will do as a starting point to build whatever you want (though i believe the 72+ chassis are a little easier to start with)
Im currently wrapping up the complete bare metal rebuild of the first 914 I ever bought (also the first car I ever bought) and am putting it back together with what I consider to be the ultimate mix and match of 4 cyl parts from all years.
72 chassis (slightly lighter than the 73s)
Mid 73 doors (no impact beams)
73+ front suspension (late struts/ball joints, brakes)
73+ side shift trans
Built 2056 (Megasquirt injection)
74 1.8 Plenum/runners (with a bored 2.1 WBX throttle body)
75 Rear vinyl "914" emblem (this was just to stick with the "lightweight" theme of the build and to not drill the rear panel)
It got a bunch of other neat stuff intended to make it the ultimate 4 cyl drivers car but ill save all the details for another thread.
