QUOTE(Thunderchief @ Apr 6 2024, 07:08 AM)
My welder is a perfectionist but 100 hours of labor? He charges $75/hour which isn't bad but it's still $7500. I live in Southern California where things can be a bit more expensive. Anyone know someone really good in the area for less $$? Thanks in advance.
Just to do the flares, probably 4k-6k
BUT (and this is a really big but)
If you do the flares then you have to repaint most of the car which is also a good chuck of change these days...
and if you are dropping all that money to do the paint, you might as well make sure all the metal under that expensive repaint isnt paper thin and full of holes and bondo given these tubs are all 50+ years old, so another 1-2k to blast the tub back to bare metal
plus whatever to fix the rust that I promise you is there.
Basically what I am saying is you could do a half assed superficial job for for 10-15k, a proper job for 30k+, or just find a car that already has flares.
This is the only way to know you are working with a clean tub. I personally dont understand why anyone would dump 5 figures to put lipstick on a pig.
