QUOTE(emerygt350 @ Apr 7 2024, 08:12 PM)
What flaca said. Old vehicle and all that. What a fun little dual oil circuit you have there. Mine is a dual pole but stuck under the front coil mount. I think it looks cleaner, but I like the fact yours still has the normal dummy light sensor in the chain, and it may not fit my way. Yours does introduce more leak points but they are all easily fixable.
The fuel smell is a worry of course. Work your way from the fuel line all through the injectors and regulator and pump. Don't drive it till you find it.
Click to view attachment Ignore the strange wires, you can see the dual pole attached to the forward coil mount. The zip tie is at least 5 HP.
Thanks for everyone's suggestions. I had a vapor issue with the fuel tank which was corrected by getting a new fuel cap.
I want to say that my smell is a mixture of fuel/oil burning. I have a lift at home and I've looked over everything else underneath. Had it even looked over by a mechanic - no fuel issue he mentioned last year.
Previous owner had replaced the fuel pump, fuel injectors, fuel filter vacuum lines, spark plugs and ignition wires.
I have tightened the pressure switch. Will run it again tomorrow to see if the leak comes back.
