Literati914
Apr 8 2024, 10:32 PM
I need to replace the original cloth covered hoses underneath the brake reservoir. Anyone know what specs it needs to be? Is it something local FLAPS will have or needs to be ordered?
Mikey914
Apr 8 2024, 11:19 PM
It's hydraulic rated hose. If you don't use that it will dissolve over time.
We stock them cut to length
You may need a set for upper and lower.
https://914rubber.com/brake-hose-9mm-set-of-2
