Literati914
Apr 10 2024, 05:07 PM
Looking for the two steel fuel lines that come up thru the engine shelf on the passenger's side. Used is fine. Shipping to Dallas TX 75233
bdstone914
Apr 10 2024, 08:50 PM
@Literati914 Original lines are plastic. Metal is used in the front from the gromett onto the tunnel.
I think Tangerine sells the pair of SS engine bay lines by them selves.
Apr 11 2024, 05:22 AM
I think I have a set of the tangerine that I didn’t use on my 3.2 conversion. I’ll check tonight.
Literati914
Apr 11 2024, 08:09 PM
No longer needed, thanks guys!
Literati914
Apr 13 2024, 03:03 PM
^^ scratch that ^^
I could use the small diameter tubing, 8mm I think - if anyone has it let over from a kit they didn't use (carbs or whatever).
Alternatively, If you have a short length of 5/16" tubing I'd buy that too. (18-24" ideally)
Old original plastic tunnel fuel lines had a metal piece at the front of the return line that would work. LMK, thanks.
