QUOTE(ClayPerrine @ Apr 14 2024, 07:00 AM)
I keep the original jack in the original six, but it will never be used. I had one of the later jacks break the shaft just above the shuttle one time. Left me stranded with the car halfway up. I couldn't change the tire, and I couldn't get the car off the jack. Luckily a guy lent me a floor jack so I was able to get the tire changed.
I use scissors jacks from 1980s, era Nissans. They are cheap, plentiful and cheap from the wrecking yards.
i used to throw the spare under the squareback near the jack incase it came down while i was trying to take the flat off.
i'd do the full exchange with at least one wheel under the car while the other was going on.
still made me anxious in the extreme carrying out the operation.
i don't know how many times i had the squareback half up and i'd look at the jack and go no...no....no. as it started to lean.
and start all over again.
i throw my renault scissor jack in whenever i take the 914 out.
all above would be exaggerated by stress level of doing up the lug bolts which VW kindly decided were superior to lug nuts. trying to hold the wheel while you got the bolts started into the hub.
