DougC
Aug 22 2005, 02:39 PM
Last week I asked a couple of questions about senders for my 2.7L, and found out that the senders up by the fan are temp and pressure (gauge) senders. But, I noticed another sender to the right of these, over on the other side of the oil fed cam chain tensioner...it is two pronged. What is this one for?
Doug C
DougC
Aug 22 2005, 02:41 PM
BTW, this sender reads "+45 degree C" & "36/3/4 and a part number.
Doug C
ArtechnikA
Aug 22 2005, 03:35 PM
my engine came with one of those too!
i have no idea what it does...
i'll go ask the 911 board and then maybe we'll both know...
DougC
Aug 22 2005, 03:43 PM
Hey..is that a subtle hint for me to check somewhere else
Well, I tend to frequent those 911 boards as little as possible these days. But, if you find out, I'd like to know too. thanks.
Doug C
Cap'n Krusty
Aug 22 2005, 04:07 PM
QUOTE (DougC @ Aug 22 2005, 12:39 PM) |
Doug C |
2.7s didn't have oil fed cam chain tensioners. Is this sender in the chain cover? Is it on ehr right or left (as seen from the rear of a 911. The CIS cars have a thermotime switch in the left cover, and some cars have a temp switch in the right cover, as well. The Cap'n
ArtechnikA
Aug 22 2005, 04:08 PM
QUOTE (DougC @ Aug 22 2005, 05:43 PM) |
Hey..is that a subtle hint for me to check somewhere else... |
no, it was a "thanks for the reminder, i've been meaning to ask about that..."
the 911 RennList guys are knowledgeable and fairly down-to-earth.
donno what it is about the Birdie Board that attracts the lunatic fringe; i don't go there very often.
IMO - ya got a 911 engine, yer gonna hafta pay a bit of attention to the 911 issues...
(got my first 914.6 30 years ago, been following 911 issues at some distance since then...)
DougC
Aug 22 2005, 04:11 PM
Yes, it's on the chain cover..I should've mentioned that. And, it's on the same side as the other two oil related senders but about as far away from the fan as possible.
Doug C
ArtechnikA
Aug 22 2005, 04:14 PM
QUOTE (Cap'n Krusty @ Aug 22 2005, 06:07 PM) |
2.7s didn't have oil fed cam chain tensioners. Is this sender in the chain cover? |
they didn't come with pressure-fed tensioners, but lots of them have been retrofitted. mine has. i don't think i'd have done it, but it came that way from the PO...
my sensor-in-question is in the leftside chain cover, and it was a CIS engine when removed from service, so the thermo-time switch makes complete sense.
Sammy
Aug 22 2005, 04:21 PM
It is a temperature sender for the CIS.
It tells the fuel injection if the engine needs (cold) fuel enrichment or not.
DougC
Aug 22 2005, 04:25 PM
Thanks Sammy, that does make since and my engine is CIS too.
Doug C
lapuwali
Aug 22 2005, 04:42 PM
Specifically, the thermo-time switch turns on the cold-start injector, which only operates while cranking. There's ANOTHER device (the warmup-regulator) which provides cold running enrichment. It's a box mounted near the throttle linkage, with a vacuum hose, a fuel hose, and at least one wire leading to it.
Cap'n Krusty
Aug 22 2005, 04:54 PM
QUOTE (lapuwali @ Aug 22 2005, 02:42 PM) |
Specifically, the thermo-time switch turns on the cold-start injector, which only operates while cranking. There's ANOTHER device (the warmup-regulator) which provides cold running enrichment. It's a box mounted near the throttle linkage, with a vacuum hose, a fuel hose, and at least one wire leading to it. |
TWO fuel hoses, one or two vacuum lines (varies with the application), and an electrical connector (1 or 2 wires, depending on the year). Mounted on the #2 intake runner. Properly called the "Control Pressure Regulator", also frequently called the "Warmup Regulator". The Cap'n
michel richard
Aug 22 2005, 06:59 PM
ArtechnikA
Aug 23 2005, 06:14 AM
Green Manalishi with Two-Prong Crown (circle).
pressure-fed tensioner update oil line (arrow).
paragraph on the back of each one, telling what each one is (this).
{if you didn't follow Fleetwood Mac in the Peter Green era, you'll have no idea what i'm talking about...}
ArtechnikA
Aug 23 2005, 06:16 AM
cr&p - i really hate that you can't edit a picture in!!
redshift
Aug 23 2005, 06:29 AM
QUOTE (ArtechnikA @ Aug 23 2005, 08:14 AM) |
{if you didn't follow Fleetwood Mac in the Peter Green era, you'll have no idea what i'm talking about...} |
As Zappa said, "Jump down, turn around, turn your Peter Green."
M
