Was running in a car i bought but needed the plug helicoil installed. Some FI is there but I would say put carbs on it.
No exhaust, needs some leaky gaskets and seals replaced. Think of it as a temp engine as you rebuild your matching numbers engine or as a core to build into your fantasy hot rod engine.
$500 pick up only outside Paso Robles CA.
Imagine just about every used 914 engine you’ve seen, good no pics are necessary then.
