vesnyder
Aug 22 2005, 06:17 PM
I have a parts car that I am removing the engine and, after potentially rebuilding, insert into my L-Jet car. What parts do I need to make sure I remove and keep with the engine? There is a harness under the passengers seat - is this something I need to keep with the engine?
Thanks
Mueller
Aug 22 2005, 06:21 PM
keep pretty much everything connected to the engine via wiring harness or hose....you don't need the relay board, but grab the relays if you can.....
if this is a 2.0, you can run your L-Jet on it with no problems.......
nothing under the seat or inside the drivers compartment is needed.....
mihai914
Aug 22 2005, 06:24 PM
Remove everything you can in the engine compartment, there should be left only the fuel feed and return lines and electrical harness that goes through the center tunnel. Once you drop the engine, there will be only the MPS an relay board still in the engine bay to be removed. Oh and the brain attached to the battery tray.
Bleyseng
Aug 22 2005, 06:36 PM
grab the fuel pump too esp if its up front.
