QUOTE(burlybryan @ Apr 25 2024, 09:26 AM)
I've got the non-easy install 914Rubber brake master cylinder. From the installation videos I've seen, there should be small metal washers between the MC and the rubber grommets for the supply lines. Do these exist within my original MC to be re-used? The new one (bought a while ago before they offered the easy install version) didn't come with them.
Thanks.
I'll add my voice to the chorus. You need them, and they are not the crush washers that go on the banjo fitting for the caliper supply lines. They came with my 914Rubber non-easy install MC and were in a small ziploc bag. Easy to lose, especially if you bought the part several years ago. Give 914Rubber a call and I'll bet they'll send you some more. I'm not a big fan of reusing easily replaceable parts, but that advice came from a more experienced member so I'm sure it's ok to reuse the old ones. Have fun getting the grommets in place. I lubed mine with a bit of brake fluid and that really helped. I used a pair of right angle pliers to push them down in place. That was the hardest part of the job... A Motiv pressure brake bleeder and three quarts of brake fluid were needed to get all the air out of the system. Have fun!
