Kerrys914
Aug 23 2005, 05:35 AM
ClayPerrine
Aug 23 2005, 05:58 AM
The hard part is not the hand throttle parts themselves. It's finding the bellcrank that attaches to the pedal box. The one on the six has a paddle that points out to the side for the hand throttle rod to press against.
The rest is just a ball stud, a ball socket, a long rod threaded to 4mm x .8 and a L shaped bracket.
john rogers
Aug 23 2005, 08:43 AM
On my race car I use the heater handle for a hand throttle. I used a section of bicycle brake cable, teflon lined, and it goes in the fire wall where the old heater solid wires came out. I do not use that bellcrank assembly so I just ran the cable up to the regular throttle cable connection. I have an angled piece of aluminum as a stop for the regular throttle cable and drilled a second hole for the hand throttle outer cable. The bike shop carries various ends fior the cable so it will work good. I have to pull the lever up about 20% before it will do anything and it does work amazingly well. Total coat was about $6 or so.
markb
Aug 23 2005, 09:32 AM
Hmmm, poor man's cruise control.....
