agrump
Aug 23 2005, 06:53 AM
Hi,
I’m converted by car back to FI using the original air cleaner and I want to reconnect the emission hoses but I can’t find them. Where are the lines that connect the engine and air filter to the charcoal canister? I see black plastic lines that connect to the charcoal canister under the front hood but I can’t find the other end in the engine compartment. Where should they be?
Thanks,
Dean
bondo
Aug 23 2005, 08:42 AM
They run down the driver's side rocker panel and come in at the corner of the engine compartment under the relay board.
dmenche914
Aug 23 2005, 11:51 AM
The lines in the rocker on driver side are hard black plastic. After they enter the engine bay they should switch to a cloth wraped rubber hose. One goes tot eh air cleaner, the other goes to the small pipe which sticks out fo the cast fan houseing near the battery/spark coil (passenger side of fan house)
If your fan house is from a non-smog car, the fitting might not be there, so a hole will need be drilled and a short metal pipe pressed into the hole to accept the rubber hose. (I have run into fan housings that lacked this port)
