Mueller
Aug 23 2005, 11:26 AM
I know some of you guys with the modern Porsche rims have got to be running spacers wider than 1"...now what size front and what size rear???
thanks
Aug 23 2005, 12:32 PM
not "modern" but ...
GT flares and cookie cutter wheels (7x15 with 225/50 tires), front 1 1/4" spacer, rear 1 1/2" spacer to fill out the flares nicely ...
Andy
rick 918-S
Aug 23 2005, 12:42 PM
smrz914
Aug 23 2005, 01:33 PM
1.5" all around 7" and 9" 993 17" wheels. I havn't had any issues with them. I have rear flares and the front fenders pulled a little.
Series9
Aug 23 2005, 01:46 PM
I have 42mm on each corner. No problem.
Joe Bob
Aug 23 2005, 02:16 PM
1 inch and 2 inch when I run the 964 wheels on the 911.
Frank runs 2.5 in the rears 1.5 up front. Havent aligned it yet but it pushes like a MOFO....
Joe Ricard
Aug 23 2005, 02:24 PM
QUOTE (SEEMORE BUTZ @ Aug 23 2005, 12:16 PM) |
Frank runs 2.5 in the rears 1.5 up front. Havent aligned it yet but it pushes like a MOFO.... |
Invert your spacers and it will be loose as a MOFO.
Track width front and back has a profound affect on handling.
Wider in the rear will the front
Wider in the front will slide the rear
Joe Bob
Aug 23 2005, 02:41 PM
Spacers are for clearance issues...I don't have a choice with these wheels. Remember...we're talking LOOKS here....not performance....
W/o spacers the inside of the wheel hits the swingarm in the rear and the inner fender wells up front...
redshift
Aug 23 2005, 02:49 PM
QUOTE (SEEMORE BUTZ @ Aug 23 2005, 04:41 PM) |
Spacers are for clearance issues...I don't have a choice with these wheels. Remember...we're talking LOOKS here....not performance.... |
FAIL! FAIL! Oh, you mean your car.
M
Jeroen
Aug 23 2005, 06:53 PM
7x16 fuchs (ET 23) front with 205/55/16 and 21mm spacers
7x16 fuchs (ET23) rear with 225/50/16 and 35mm spacers
neo914-6
Aug 23 2005, 07:04 PM
Mines not running but no one else is reporting on performance differences so...
18x8 ET50 43mm spacer
18x11 ET63 76mm spacer
yeah I'm all about looks anyway
TimT
Aug 23 2005, 07:42 PM
2'+ spacers on the rear of the 935, and 1.5" on the front, we often go wider than 2.% in the rear depending on which rubber/wheel combination we are running.
Last time I drove that car it handled ok
GeorgeRud
Aug 23 2005, 09:51 PM
My flared 914-6 has Fuchs (7x15 fronts and 8x15 rears) with only 1/4 inch spacers in the rear to space them out. The steering is much heavier than my other 914-6 with the stock 5.5 x15 Fuchs at low speed, but not noticable while driving. Since most of the new wheels have very much rear offset compared with the old Fuchs, you just have to space them to fill the flare. I've always wondered what some 8x17 and 9x17 Ruf wheels would look like on a flared 914, but have never found anyone who has done this (or wants to sell a set somewhat reasonably).
Mueller
Aug 24 2005, 08:23 AM
QUOTE (GeorgeRud @ Aug 23 2005, 08:51 PM) |
I've always wondered what some 8x17 and 9x17 Ruf wheels would look like on a flared 914, |
hi George, I didn't know you had an original /6 as well
it appears only the rear fenders have been pulled out, but those are RUF wheels
GeorgeRud
Aug 24 2005, 04:21 PM
Have to have 2, they're small. I contacted the RUF Centre in texas today, and they are going to be getting more 17 inch wheels in after about 10 years of no production. About $2800, so no bargains.
As I thought, the car looks pretty good with the Ruf wheels. Thanks for the picture.
