bd1308
Aug 24 2005, 12:29 PM
not dizzy, not pre-ignition....(present in all extremes of timing)
what in the world could this be?
did i snap a piston ring or something, is it piston slap, engine ticking until it goes KABLOOM or what?
sounds like someone put a nut in the fan and its goign clak clak somewhere...under moderate acceleration..
seems vibration related really, as when i first let out on the clutch i hear it for a second.
SGB
Aug 24 2005, 12:39 PM
this may seem whacked, but check the brake lines at the firewall where the perportioning valve is. I had one line that vibrated against the firewall at certain RPMS and load conditions and made a sound like you are describing.
Gary#
Aug 24 2005, 12:40 PM
That happened to me too -
I removed my wife from the trunk & the strange noise stopped.
tat2dphreak
Aug 24 2005, 12:41 PM
maybe you are running too lean from feeding your engine through a fucking straw...
is there a "pinging" sound? loose valves? when was your last valve adjust? did your VW mecahinc friend do it?
i HIGHLY DOUBT you sontaneously dropped a piston ring or a wrist pin... but with you, who knows?
did you do a compression check? do you know HOW to do a compression check?
help us out here... we can't heard it over the net through your post...
or take it to a real mechanic that KNOWS type 4s... not just type 1s
bd1308
Aug 24 2005, 12:43 PM
that's what i'm doing. i'm finished messing with the dumb car....
scotty914
Aug 24 2005, 12:44 PM
check you engine and tranny mounts, and while under there take a small rubber hammer and hit the tins, HE, every thing that can move or viberate. does the sound come from the middle of the car, back ???. i wonder if your throw out bearing is going bad ie, the sound when you let off the clutch
tat2dphreak
Aug 24 2005, 12:46 PM
it could be 1000 things with the descriptions used... things do get loose on 30+ year old cars...
bd1308
Aug 24 2005, 12:47 PM
engine mounts are okay---
one tranny mount was kinda ugly...but still held.
i hear ya, i know i'm being stupid here by asking what a rattle sound is....
i'll just take it to the mechanic, the porsche one.
tat2dphreak
Aug 24 2005, 12:51 PM
QUOTE (bd1308 @ Aug 24 2005, 01:47 PM) |
i'll just take it to the mechanic, the porsche one. |
a p-car mech may not know t4s either... oh nevermind...
bd1308
Aug 24 2005, 12:53 PM
naw, this guy is good.
he's kinda far away, but he AX'd 914s in the 70s and 80s....
he has a 914/6
he's done many restorations on 914s, complete tear-downs and what-have-you.
TravisNeff
Aug 24 2005, 01:12 PM
Pebbles in the melon?
bd1308
Aug 24 2005, 01:27 PM
QUOTE (Travis Neff @ Aug 24 2005, 01:12 PM) |
Pebbles in the melon? |
oh my....That's it....I beat my head against the wall and it made the same sound...
tat2dphreak
Aug 24 2005, 01:38 PM
QUOTE (Travis Neff @ Aug 24 2005, 02:12 PM) |
I was thinking it was a "loose nut behind the wheel"
Aaron Cox
Aug 24 2005, 01:44 PM
brain rattling around in your head? or the gears in your mind that need lubing....
Joe Ricard
Aug 24 2005, 01:54 PM
QUOTE (bd1308 @ Aug 24 2005, 11:27 AM) |
QUOTE (Travis Neff @ Aug 24 2005, 01:12 PM) | Pebbles in the melon? :lol: |
Just keep doing what you are doing it will stop.
