vesnyder
Aug 24 2005, 02:29 PM
Looking to ugrade my Master Cylinder and wanted to know what year the MC's from the 911 will fit the 914? Anything else to be aware of?
Cap'n Krusty
Aug 24 2005, 02:35 PM
1968-1976
911 355 012 02
The Cap'n
bondo
Aug 24 2005, 02:41 PM
Get new rubber reservoir inserts. Trying to reuse old ones is pure masochism. It also helps to disconnect the lines from the reservior end so you can pull them down a bit and get them in before raising the master cylinder into place.
vesnyder
Aug 25 2005, 05:30 AM
Thanks for the input.
QUOTE |
Get new rubber reservoir inserts. Trying to reuse old ones is pure masochism. It also helps to disconnect the lines from the reservior end so you can pull them down a bit and get them in before raising the master cylinder into place. |
Bondo - Thanks. I did read some horror stories and I am going to replace the reservoir anyway.
xsboost90
Aug 25 2005, 06:30 AM
best price i got on one was from gprparts.com and just told him i was putting it on a 914 wanted 19mm he said ok and shipped it out. If you get one from a 911 make sure its not a power brakes model..
