Full Version: Electrical: Turn signals not working
dennisphelan
I have this strange problem. The front and rear turn signals work until I turn on the headlights. The front turn signals stop working, but the rear ones continue to work. Where should I look?
Dennis Phelan
dennis.phelan@gmail.com
NARP74
Stock bulbs or LED conversion?
Dave_Darling
Check the wiring for all four turn signal buckets. Having a couple of wires switched can cause this behavior.
Search through this page for drawings of how they should be wired: https://bowlsby.net/914/Classic/TechNotebook.htm
--DD
dennisphelan
Sorry for the late reply. They are LED conversions
Spoke
Hey Dennis,
As Dave mentioned, check the wiring on the front buckets. Make sure the ground is connected to ground. The only connection between turnsignals and headlights is the dual filament front turnsignal sockets where the low intensity light is powered by headlights and the high intensity light is powered by the flasher relay.
