Full Version: Spark Plug Wrench
Literati914
I’m gonna pick one of these up and was wondering if anyone here has tried one? My only concern is the depth of the socket part itself.. could be a little short?
windforfun
Scale the drawing.
Literati914
QUOTE(windforfun @ Aug 26 2024, 02:45 PM) *
Scale the drawing.
I mean.. I only have 3rd grade math.
windforfun
QUOTE(Literati914 @ Aug 26 2024, 12:58 PM) *
Scale the drawing.
I’ll get back to you when I have a real keyboard in front of me.
ClayPerrine
If you want one, I will give you mine.
And I don't give away useful tools.........
Literati914
QUOTE(Literati914 @ Aug 26 2024, 02:58 PM) *
Scale the drawing.
QUOTE(windforfun @ Aug 26 2024, 03:09 PM) *
Scale the drawing.
lol-2.gif Just kiddin' I'll go ahead and get one, it should be fine - I mean it is a spark plug wrench .. surely they didn't screw up the depth for an average spark plug. Was just hoping someone could tell me if they hated it, and maybe point out a better alternative.
Literati914
QUOTE(ClayPerrine @ Aug 26 2024, 03:13 PM) *
Geezer914
Just use a socket and extension, you should be torquing the plugs with aluminium heads.
Shivers
You have to be GI Joe with the Kung Fu grip to use that to remove old plugs from a cylinder head. At least in my experience.
worn
QUOTE(Literati914 @ Aug 26 2024, 12:42 PM) *
It is sort of like the factory part. I like the factory part coupled with the supplied Allen wrench. Gets into tight spaces, and I have the racket version of the Allen wrench.
Literati914
QUOTE(Geezer914 @ Aug 26 2024, 03:19 PM) *
QUOTE(Shivers @ Aug 26 2024, 03:28 PM) *
Good points. I like this for the simplicity of it. Easy to recognize as the spark plug wrench and easy to put your hands on quickly. "Oh there's my plug wrench" - rather than searching/fumble around with the correct ratchet, extension and socket.. That's gotten old already. This should work for at least the initial R&R.. then follow up with a torque wrench, which was always ideal anyways.
Do plugs tend to stick in heads that are in regularly use? or just in ones that have been sitting in a field for several years? - LMK, I'm really not sure on that. I think I've read anti-seize on the plug threads, as a recommendation?
Literati914
QUOTE(worn @ Aug 26 2024, 03:39 PM) *
I'm not sure about the exact 914 supplied item, but the one I have is just a 6-7" pipe with the correct socket opening pressed on one side. There is NO rubber insert and you have to fit a screwdriver into a hole on the side to get it to turn. Again, a sloppy solution imho. Yours may be better - I have seen some that are similar to what I posted above.. Klein tools maybe, but I assumed they were 911 items.
914sgofast2
That wrench looks like junk designed by someone who has never had to change a spark plug.
Literati914
QUOTE(914sgofast2 @ Aug 26 2024, 04:47 PM) *
Oh ok, your favorite plug removal tool is... ?
windforfun
QUOTE(914sgofast2 @ Aug 26 2024, 02:47 PM) *
I don't think it's made by Snap-on.
Geezer914
Like I said, if you are using a torque wrench to tighten your plugs, you have found the socket and the extension you need. That tool is worthless!
Superhawk996
Not sure that spring-a-ma-thing is going to clear the tin. Even it it does go into the tin, it looks like a nightmare trying to extract the plug without spring and/or the built in U-joint hanging up on tin and dropping plug into the tin.
Then you’ll have to go find the springy grabber thing or the magnet on the wand and play Operation to retrieve the spark plug headbang.gif
Literati914
QUOTE(windforfun @ Aug 26 2024, 05:36 PM) *
QUOTE(Geezer914 @ Aug 26 2024, 05:45 PM) *
Ok, yeah I have to admit it does look a little flimsy... good thing I was lazy and didn't buy it yet (thanks for saving me the frustration biggrin.gif )
I might buy the Klein version though. Those look a little more HD. I can not argue against a torque wrench but there is certainly a place for stand alone plug wrenches IMHO.
Literati914
QUOTE(Superhawk996 @ Aug 26 2024, 05:59 PM) *
Now that's a good point, and it's why I mentioned the length of the socket itself in my first post. If the socket is long enough (really looks like it's not tbh) the spring wouldn't be down in the tin to get hung up.
Shivers
@Literati914
They can stick, any place where water or even more so acid rain can get to the plug / head area. And yes that is what I do, permatex has an anti seize for aluminum.
bkrantz
And make triple sure the wrench will retain a lose plug, and not drop it inside the sheet metal.
worn
QUOTE(Literati914 @ Aug 26 2024, 01:50 PM) *
Yeah. From my 911. Sorry. Factory part was misleading.
McTyke
QUOTE(Geezer914 @ Aug 26 2024, 08:19 PM) *
The spark plug socket I have, which is from a Kamasa Tools socket set, works fine on cylinders 1, 2 and 4 but won’t engage the plug on cylinder 3. There seems to be some part of the cylinder head that snags on the socket preventing it from sliding all the way down over the plug. I guess I need a thinner walled socket or to file away the outer wall of the socket enough for it to clear the obstruction. Anyone else have this issue?
Mine is a 1.7/1.8 litre type head.
VaccaRabite
QUOTE(McTyke @ Oct 28 2025, 10:33 AM) *
That is a REALLY weird problem, and I suspect you have something else going on.
#3 is one of the easiest plugs to get to. #2 is always the hardest plug, followed by #1 - the two deep ones.
If #3 is stuck, I would guess its rusted in place or cross threaded. Spraying penetrating oil down there will help either of those. If its badly cross threaded you will want to fix the head before you jam another plug down there.
Zach
Literati914
QUOTE(McTyke @ Oct 28 2025, 09:33 AM) *
.. There seems to be some part of the cylinder head that snags on the socket preventing it from sliding all the way down over the plug. I guess I need a thinner walled socket ..
Is that not a temperature sensor wire/ring sitting under the #3 plug (they are usually under #3 when used), that's fouling your socket? - yeah a thin stock type socket would probably be helpful in that case.
