I put the tires on the teener to actually DRIVE it...
I eased it down, I noticed the rear was too low and the front is too high(no hood and almost no gas in the tank though)
the rear tires were rubbing the fender (which it didn't do before) I had changed shocks, and put new rear Bils on with shorter, 120# springs on, so I thought it just needed adjusting... I raised it up 2 spots, same thing, still rubbing(just not as much, but if I hit a bump, whoa nelly... ) so I inspected further... fronts and rears are BOTH 195/50s, but different brands... on the rear was Federals and the front had FIsk... don't blame me, I didn't pick them... they were put on by the PO...
the rears, eventhough they are the same size and rims are the same, the rears(federals) were ballooning MUCH more on the OUTSiDE than the fisks on the front... so, out of curiosity, I swapped the tires to where the fisks are on the rear now... no rubbing. everything great!
is that not the most F'd up thing?!?!
btw, the car moved under it's own power for the first time in 2 over years!! today I drive it to make sure everything is ok(other than the front sticking up too high) and tonight it goes to the new house.
