Brando
Aug 27 2005, 06:34 PM
Died when hitting a speed bump in LA today. Checked my rickety temp. sender wire and when I ground it out the gauge reads all the way in the red. I believe it's the sensor in the oil pan.
Where can I get one ASAP?!
qa1142
Aug 27 2005, 07:45 PM
Make sure you get right one 200 deg
Brad at 914ltd likely has them
Dave_Darling
Aug 28 2005, 07:43 AM
The "reads all the way hot" means that the gauge is seeing zero resistance--a dead short to ground. When this happened to my car, it was because the wire to the sender had gotten chafed and was grounding on whatever it was that rubbed the insulation off. I spliced in new wire and re-routed, and all was well with the gauge.
--DD
Michael J
Aug 28 2005, 11:08 AM
If it's an OEM gauge you might try Rich Bontempi. I got a sending unit and taco plate from him a month ago.
Rich Bontempi's High Performance House
messix
Aug 28 2005, 11:12 AM
mine got pinched between the engine bar and the engine case. rerouted and fixed the wire.
Brando
Aug 28 2005, 12:42 PM
Thanks guys... I'll get the car on jack stands this afternoon and see if the wire is disconnected or broke...
Like I said, I know the gauge works because I grounded the wire and it read all the way hot, re-connecting it read arctic tundra (cold). I'll see if I can get a new taco plate and temp sender from Rich, if not then GPR it is.
