Rennshift is an excellent shifter! I have bought
two and plan on
buying many more. Rennshift is the shifter I am using in my 3.6 project. James is a pro and does exactly what he says he will do.
5 STARS!1970 Factory 914-6, 3.6 964 Engine, 50MM PMO Webers, Electromotive Twin Plug Crank Fire, Aase RSR Valve Springs with Titanium Retainers, WEB Euro Spec Grind Camshafts, PatrickMotorsports 1 3/4" Jet Coated Racing Headers with PatrickMotorsports Silencers, 901 Converted Side Shift Transmission with Factory 904 Main Shaft and A,E,J,Q,X Short Gears, Billet Aluminum Intermediate Plate, 225MM PatrickMotorsports Racing Clutch, PatrickMotorsports RSR Billet Aluminum Flywheel, Quaiffe LSD and Billet Side Plate, PatrickMotorsports Solid Transmission Mounts, Tilton Transmission Pump System with HD Fluidyne Oil Cooler, B&B 930 Front Mounted Engine Oil Cooler with Thermostat, 911SC Front Suspension with Aluminum Cross Brace, Porsche Twin Turbo Brakes and Rotors Front and Rear, Pagid Racing Pads, 23MM Gun Drilled Front Torsion Bars, 930 Turbo Tie Rods, Charley Front Sway Bar, Porsche Factory Rear Sway Bar, RSR Threaded Front Bilstein Struts and Sport Valved Shocks, Eibach 275lb Rear Coilovers, Racers Group Adjustable Monoball Upper Strut Mounts, Poly-Graphite Suspension Bushings, 19MM Master Cylinder, 17 X 8 & 17 X 9 1/2 Kinesis Polished 3 Pc. Wheels, 914-6GT Chassis Stiffening Kit, 914-6GT Boxed Rear Suspension,
RennShift Performance Shifter with Steve's Custom Fab Linkage, Full Chrome-Moly through the Bulkhead Cage, Porsche Factory GT Flares Butt Welded, 5Five5 Composite Front and Rear Hoods and Bumpers. Terazoom Quick Release Steering Hub. MOMO Prototipo Wheel, MOMO Competizione Shift Knob, MOMO Composite Racing Seats, SPA Fire Suppression System, Patrick Motorsports 914 Tank Fuel Safe Fuel Cell, Martin Baker Vintage GT Gas Cap, Boman Graphics, Steve Aven Crew Chief (714)-634-1234...
